Re: Poor Glueing
Posted by Charlie on Sep 10, 2007
If you apply heat with a heat gun you should be able to soften the epoxy and pull the pieces apart. If you go easy on the joint you can get the components apart cleanly you shold be able to clean off whatever epoxy is pesent and reglue the joint.
In Response to: Poor Glueing by Rich on Sep 10, 2007
