Re: lol- paint IS the
Posted by Robert N Pruden on Sep 7, 2007
If you want to protect the bottom of the hull then you do not want to use paint. You want to use an epoxy-cabosil (silica) mixture. Use a 10% v/v mixture of graphite powder/silica/epoxy, coat at least three times and you'll have a hull surface that sharp rocks scratch but can't penetrate unless you hit them with very hard force. The grapite powder acts as a lubricant and the cabosil creates a harder finish. The mixture should be easily spreadable and spreads nicely with a quality foam brush (not the cheap dollar store brands). If you want, you can use the mixture to paint other parts of the kayak as well. Be warned though: refinishing the graphite mix coated surfaces requires a lot of sanding because it is a very abrasion resistant finish. Hope this helps ya more.
Oh yeah, in hindsight, Charlie's suggestion seems ok to me since I bang up my paint work so much I redo it every two years anyway, so varnish then paint away.
Robert N Pruden
In Response to: Re: lol- paint IS the by GCarrell on Sep 7, 2007
