Re: Work Table
Posted by Robert N Pruden on Sep 7, 2007
You can glue the scarf joints on the floor assuming it is level. An 8' table is long enough. Use pieces of wood to make grooves on the table top to anchor the keel once the hull is built. That is how I did my builds. Worked rather well. The hull can be worked on upside down using only the saw horses
Robert N Pruden
In Response to: Work Table by John on Sep 7, 2007
