Re: Help needed
Posted by Jim E on Sep 4, 2007
If the glue has cabosil or woodflour in it, the stray bits may be visible to close inspection - otherwise not. But thickened epoxy is less likely to creep under the tape anyway. The sheer clamps are quite hard to see in the finished hull in any case.
In Response to: Re: Help needed by Tim Clark on Sep 3, 2007
