Re: Side panel joint help
Posted by OOPS on Aug 25, 2007
Woodie's right. Edge to edge for your panels. Bevel or round the touching edges slightly so you don't have the two sharp edges hitting each other. If the edges are sharp they tend to slip out of alignment when you tighten the wires and try to align and wind everything. With a slightly wider edge (small round or bevel), your panels will hold their shape/position easier. Good luck.
In Response to: Re: Side panel joint help by Woodie on Aug 25, 2007
- Re: Side panel joint help by Kyle Lindstrom on Aug 25, 2007
Re: Side panel joint help by Jon T on Aug 25, 2007
- Re: Side panel joint help by Kyle Lindstrom on Aug 27, 2007
