Re: Unstarted Kits?
Posted by Ron Eike on Aug 16, 2007
I have used old MAS epoxy without problems except for the yellow cast. As Lazlo suggests, mix up a trial batch and see what happens. I believe that CLC was using MAS back then. One caution would be not to use new resin with old hardener or vice-versa. I think that MAS changed something since then, but a call to their help line would confirm it. Also, somewhere along the line the pumps were changed so if one goes replace them both.
Ron
In Response to: Re: Unstarted Kits? by Laszlo on Aug 15, 2007
