Re: Locate combing Ches17
Posted by Woodie on Aug 13, 2007
Don't cut the coaming hole before attaching the deck. If you have a kit, a little bit of the opening has been cut, but it is not to size. This is to allow for the shifting of the deck a little as it is put on. Basically, the coaming will sit on both of the deck beams. After the deck is attached figure out where the coaming needs to be.
In Response to: Locate combing Ches17 by Robert Miller on Aug 12, 2007
- Re: Locate combing Ches17 by Robert Miller on Aug 13, 2007
