Re: MAS and System3
Posted by craig on Aug 10, 2007
I think that if the previous epoxy is well cured, you can put whatever you want on as the next coat. As long as you properly stir your epoxy they all work about the same. The only diffence that I have seen is that the less expensive brands look slightly muddier or yellowed then, say system3 silver tip. I have been using that recently because it is so clear it gives a much deeper look to the finish.
In Response to: Re: MAS and System3 by Dave houser on Aug 9, 2007
- Re: MAS and System3 by Steve U on Aug 16, 2007
- Re: MAS and System3 by LeeG on Aug 16, 2007
Re: MAS and System3 by CLC on Aug 16, 2007
- Re: MAS and System3 by craig on Aug 17, 2007
