Re: glassing procedure
Posted by Buff on Aug 10, 2007
Just got done glassing a shearwater 16 laid up the cloth dry and poured and spread. Can see no reason to precoat the boat, and if you don't get to the glass within 24 hours you lose the chemical bond between first and second coat. The extra coat of epoxy is just adding weight and no strength. Just my 2 cents. Buff
In Response to: glassing procedure by Eric on Aug 10, 2007
