Re: MAS and System3
Posted by John Beck on Aug 9, 2007
Jeff, Using different brands of epoxy is ok as long as you don't mix components between brands.
CLC sells both System 3 Silver Tip, and MAS brands, and both use 2:1 ratio of resin to hardener. They sell pumps for both and they say they are interchangable since the ratios are the same.
I'm not sure what type of System 3 you have, but the hardeners for Silver Tip are not compatible with their General Purpose Resin, according to Sys 3, so you can't mix them.
Good luck, John
In Response to: MAS and System3 by Jeff T on Aug 8, 2007
