Pax 20 deck install
Posted by Tyler Powell on Aug 6, 2007
I'm building a Pax 20 and am about to install the deck. It does not seem that the aft deck will mount flush with the sheer clamps at the end due to the end pour. The kingplank will raise the deck up past the sheer clamps 3/8 of an inch at the end pour. The instructions do not mention anything about this sort of problem. The only thing i can think of to fix this issue is to cut a slot into the end pour. Any suggestions? Thank you for your time.
- Re: Pax 20 deck install by CLC on Aug 7, 2007
