Re: Varnish Fisheyes
Posted by J. Schott on Aug 5, 2007
I would also skip the wipe down with 333. I don't do it on my boats because it softens the varnish too much for my taste. I've had it wrinkle up brightsides before and haven't used it since.
When I wet sand, I add a drop of dishwashing detergent to my water bucket. I helps keep the paper from clogging and I suspect it also helps clean the surface. I give it a good rinse after to remove any residue and let it air dry. A wipe with the tack rag is the last step right before varnishing.-Joey
In Response to: Re: Varnish Fisheyes by GeneP on Aug 5, 2007
