Re: Varnish Fisheyes
Posted by GeneP on Aug 5, 2007
John,
You are correct, the problem is small depressions combined with more dust than in previous coats.
I am varnishing the boat on our screened porch. Before moving the boat out there we removed the furniture, vacuumed and washed the entire porch. I move the boat out to the driveway for wet sanding, rinsing and drying before moving it back. The boat stands that I used for sanding are not the same ones that I use for varnishing. I do wet the floor with a spray bottle before varnishing, wear clean clothes, hair net and beard guard.
Thinking back to the fourth coat, which looked great, I remembered that it had rained the night before so the trees/grass was still wet when I varnished. I suspect that helped to hold down airborne contamination.
Before varnishing again I am going to clean the porch again and tack up the thin painters plastic around the full interior of the porch. I am not varnishing in the garage because there is a CH16LT under construction there.
I like your suggestion of letting the tack cloth air for a day and running the roller and brush over masking tape. That will be part of the process.
Once again, thanks for the suggestions.
In Response to: Re: Varnish Fisheyes by John Beck on Aug 4, 2007
- Re: Varnish Fisheyes by J. Schott on Aug 5, 2007
- Re: Varnish Fisheyes by Chris on Aug 7, 2007
