Re: skerry-capsizing,prot
Posted by SD Roberts on Jul 30, 2007
David Bixby has put floatation bags under the mid thwart, around the daggerboard case, and finds it helps bring the daggerboard slot higher than the flooded waterline of the boat. This means that it is less likely that water will come in through the slot when the boat is flooded.
In Response to: Re: skerry-capsizing,prot by Steve Miller on Jul 28, 2007
