Re: epoxy mishap
Posted by Laszlo on Jul 26, 2007
Larry,
I think that this is a little different than Les' situation. Les had extra hardener, so there was enough for all the resin to cross link with. You only have 1/2 the hardener you need, so half of you resin will never cross link.
Brushing more hardener on top may let some of the resin cross link, enough so that with a heat lamp it may form a hard surface crust, but the inside where the extra hardener never reached will still stay flexible. If it was my boat I'd scrape it all off and try again.
In Response to: epoxy mishap by larry on Jul 25, 2007
- Re: epoxy mishap by larry on Jul 27, 2007
Bite the bullet, scrape by Charlie Jones on Jul 28, 2007
- Re: Bite the bullet, scra by larry on Jul 31, 2007
- Re: Bite the bullet, scra by Jerold Wenger on Aug 3, 2007
