Re: twisted hull
Posted by CLC on Jul 14, 2007
I have fixed these a number of times with a sharp Japanese Saw (including here at the WoodenBoat School in Maine, in whose WiFi-enabled parking lot I'm sitting). Slit the seam, squirt some glue in, slide the parts back into non-twisted alignment, and let it cure. Problem solved. Elapsed time: about ten minutes. The fix is invisible even in a varnished boat.
In Response to: twisted hull by davidtudryn on Jul 14, 2007
