Re: Sailrig Ama Height
Posted by LeRoy on Jul 9, 2007
Roger,
Beautiful looking SailRig!
I can�t give you an answer on the proper amas height above waterline, but I noticed that the end of your akas � when compared to images on the CLC site � has a pronounced downward sweep that may be the cause of your problem.
If the images on CLC�s site are of the new MK2 SailRig, you may have an older set of plans (I�m assuming you don�t have the kit)... but, since the line drawing on their site looks like it�s dated 1991, it may be the other way around... who knows??
You may want to email or call CLC direct for an answer... anyway, if you find out why your amas ended up being too low, please post the reason.
In Response to: Sailrig Ama Height by Roger Lopata on Jun 30, 2007
- Re: Sailrig Ama Height by Roger Lopata on Jul 18, 2007
- Re: Sailrig Ama Height by LeeG on Jul 24, 2007
