Wash the boats, then sand
Posted by Charlie Jones on Jul 2, 2007
Don't try just sanding. You might even wash it down with some lacquer thinner before sanding.
Once the hull is clean, THEN sand, reapply epoxy, sand again , then varnish.
You risk getting contaminatioon into the surface by sanding a dirty hull. That could easily cause trouble the rest of the life of the boat. Sanding would just imbed that contamination into the scratches left by the sandpaper.Even 600 grit leaves scratches.
You are correct Robin.
In Response to: prep to finish by Robin Thompson on Jul 2, 2007
