Re: SW Hybrid Inside Deck
Posted by craig on Jun 26, 2007
There is no need to use epoxy for strength. If you needed to that then you would have to epoxy the strips together. Epoxy is used because most wood fillers use linseed oil as a carrier and it can contaminate your epoxy. Durhams does not do that and it dries to a very light weight. I have used it untinted on some boats and have a lot of people think that I have refurbished an antique.
In Response to: Re: SW Hybrid Inside Deck by John Beck on Jun 26, 2007
