Re: Raised glass fiber
Posted by Jim E on Jun 14, 2007
This happened while the kayak was mostly sitting about? Was it out of doors? If so, this might be UV-induced deterioration in the epoxy. If you can sand away all the flaky bits without removing the glass, you can build up from there, otherwise you might need to go to the wood.
In Response to: Raised glass fiber by Jim McLean on Jun 11, 2007
