Re: Deckbeam springback
Posted by Paul on Jun 6, 2007
When you say that you only got a 1/2" of springback are you saying that your radius of your glued beam is 15 1/2" ? Or did the ends of the beam lift 1/2" from the ends of the form? The former will be much closer to 16" than the latter but in either case I wouldn't lose any sleep over it. Just make sure your sheer clamp planing guide is the same radius as your glued deck beam.
In Response to: Deckbeam springback by Jeremy on Jun 5, 2007
