Re: Yakima footbrace
Posted by CLC on May 31, 2007
>>>>>>>I am installing the Yakima footbrace rudder control. Question: When the rudder is in the center position, do you align the sliders with the tracks ends to ends? >>>>>
Yes. I always recommend a sit in the boat in the grass for a "reality check" before holes are drilled and wire cut.
>>>>How do you keep the sliders from moving during installation? >>>>
Duct tape or some such will temporarily hold things steady while you work.
This bulletin board is a free-for-all; if you need a speedy and direct response, click on "Ask for help: CLC Tech Help Line" at the top of this page.
In Response to: Yakima footbrace by Julian on May 28, 2007
