Re: Sander discs
Posted by John Beck on May 23, 2007
Garland, a ROM seems like overkill for sanding between coats. I put powered sanders away before the first finish coat of varnish or paint and do hand sanding for all finish work. I have found 220 is plenty fine for between coats. I use 3M gray scotch bright intended for sanding between coats with good success to knock off the gloss without removing much finish and it's easier to control along the chine and keel. The scotch bright doesn't clog like 220 grit paper does.
Good luck, John
In Response to: Sander discs by Garland Gray on May 23, 2007
- Re: Sander discs by Garland on May 23, 2007
Re: Wet sanding is easy by James Eager on May 24, 2007
- Re: Wet sanding is easy by Laszlo on May 24, 2007
- Re: Wet sanding is easy by Norm on May 24, 2007
