Sander discs
Posted by Garland Gray on May 23, 2007
The finest grit I can find for my ROM (hook and loop)is 220.
Is there any point in using the ROM for the #320 to #400 grit (if they can be found) suggested for sanding between coats of paint ? Or just use a sanding block ?
- Re: Sander discs by John Beck on May 23, 2007
Re: Sander discs by Garland on May 23, 2007
- Re: Wet sanding is easy by James Eager on May 24, 2007
- Re: Wet sanding is easy by Laszlo on May 24, 2007
- Re: Wet sanding is easy by Norm on May 24, 2007
