Re: Fiberglass "Seam"
Posted by Jim E on May 22, 2007
The 'step' will still be there after coating with epoxy, as you have discovered. Yes, you should blend it by sanding, then coat it with epoxy to cover the cut glass. The extra strip is quite a good idea, although it's a little easier to blend if you put it underneath the main glass. Yes, that advice is too late for this hull, but next time....
In Response to: Fiberglass "Seam" by Tim Clark on May 21, 2007
