Re: Curvature of aft hatc
Posted by Garland on May 21, 2007
I'm not sure I follow you. Of course, my kit didn't come with frames (I'm referring to the ribs glued to the underside of the hatch) so I had to make some. Not sure if cure time makes any difference in heat releasing the epoxy bond. I did mine within a day or two.
In Response to: Re: Curvature of aft hatc by Kim on May 21, 2007
- Re: Curvature of aft hatc by Jim E on May 22, 2007
- Re: Hatch curvature by Kim on May 22, 2007
