Re: Deck Beam in the way
Posted by Matt R on May 21, 2007
Thanks Jon and Woodie,
I'm going to try your advice. I'll just line up the front of the opening with the back of the deck beam and see where it lies with the bulkhead. I measured it and it should be 1/4 inch forward of the bulkhead. I need to make a template. I tried using pins through the plans to create a pattern on the deck and that's how I cut the opening about an inch and a half proud. I didn't cut the opening until I had the deck on the boat, because I didn't trust my ability to line up the center line. I can see the light at the end of the tunnel, getting excited!
In Response to: Re: Deck Beam in the way by JonB on May 21, 2007
