Re: Paint, Sand, Varnish
Posted by Shawn on May 14, 2007
Thanks John. So you're saying.. 99.6% of all that primer i added needs/is coming back off.. nice.. now you see, i had a nice finish of epoxy, so i guess i could have stopped priming at the keels, i thought the primer was to help "whiten" the "background" so the over-paint will coat better. Ah.. whats another hour or two..
Ron, I should have stated that I'm using Interlux (pre-Kote) and Brightsides one part, for the paint, and Interlux Schooner varnish for the deck.. I'll call the manufacture and get some "wisdom" from them. But seven days w/o working on or paddling in that kayak.. not a chance! [smirk]
I'll find out if that cold Maine water (sub 50F) does any damage to the paint.
Shawn.
In Response to: Re: Paint, Sand, Varnish by John Beck on May 14, 2007
- Re: Paint, Sand, Varnish by Ron Paro on May 14, 2007
