Re: Small bubble under gl
Posted by Willy on May 12, 2007
Paul,
I had great luck getting rid of bubbles with a syringe and needle filled with epoxy. If you've only put one coat of epoxy on your glass there will undoubtably be small holes in the glass where the bubble is. Simply inject some epoxy into the hole and move on!
Linky:
http://www.woodcraft.com/family.aspx?familyid=3231
In Response to: Small bubble under glass by Paul D on May 11, 2007
- Re: Small bubble under gl by birch on May 13, 2007
