Re: That's the way
Posted by Jim E on May 11, 2007
If you have a helper, your could pick up the boat with one person at each end. Hold it level while taking turns at stepping on the scales. Then subtract your personal weights.
(If your helper's weight is a secret, tell her your readings and she'll do the math for you)
In Response to: Re: That's the way by OOPS on May 11, 2007
