Re: "Flush" SW Deck?????
Posted by LeeG on May 7, 2007
thinner gasket tape?
The little trim rim makes sense for the top mounted hatches given the mismatching curve between the underside the hatch and the deck but for the flush mounted hatches the hatch and deck are matched nearly perfectly. It doesn't seem that the little rim would be as necessary. I never had leaks with flush hatches as long as the gasket was trimmed and applied without a gap.
In Response to: "Flush" SW Deck????? by John Beck on May 7, 2007
