Re: Nonstick to epoxy?
Posted by LeeG on May 6, 2007
this is what you'd do LONG AFTER everything is all glassed up and you intend on painting the hull to cover the mess because it HAS to be perfect. Personally I think it's like putting lipstick on a farm animal to fair a four panel hull with fairing compound. If you were making a 500lb sailing hull or 20ton trawler it would make sense.
J.Schott suggestion makes a lot more sense if you haven't glassed anything yet.
In Response to: Re: Nonstick to epoxy? by Julian on May 6, 2007
