Re: Mill Creek Rub Rails
Posted by Charlie Jones on May 1, 2007
Finish the boat otherwise, caulk, not epoxy, the rub rails on, using the nails CLC provides, OR 3/4 bronze boat nails. DON'T epoxy them on.
Sooner or later you'll want to replace them or repair them. If they are caulked on you can easily do that. If they are epoxied on, you've made yourself a LOT of work, unnecessarily.
The purpose of rub rails, after all, is to protect the deck edge from damage.
In Response to: Mill Creek Rub Rails by Chris J. on May 1, 2007
