Re: Epifane RapidCoat War
Posted by Rod Tait on Apr 30, 2007
We use RapidClear as a base on all our boats and then top off with several layers of high gloss. It is my understanding that rapidcoat is tinted which is probably not what you want if you do any sanding as you will sand into the layers giving you varying degrees of tint. I have no problem using or recommending RapidClear as a base.
In Response to: Re: Epifane RapidCoat War by Michael on Apr 24, 2007
