Re: Compartment leaks
Posted by Ed, NY on Apr 28, 2007
If you do not like the look of that kind of inspection hatch, you might want to take a look at the way flush hatches are made and put a small version into the "bulkhead". If you cut carefully the cut out becomes the hatch with a perfect grain match. Lots prettier than black plastic or rubber.
In Response to: Re: Compartment leaks by CLC on Apr 16, 2007
