Re: Rapid Pluse Back Band
Posted by Rick Langer on Apr 27, 2007
I did install the shock cord suspension. My problem is that the backrest is too low. I was looking at it this morning and I think maybe I should make the whole setup tighter. I'll try it, but I was thinking of a solid pad against the coaming, probably not the best solution.
By the way, Chris, what do you use for under thigh support? I noticed my legs going to sleep after about 20 minutes.
Thanks, Rick
In Response to: Re: Rapid Pluse Back Band by Chris J. on Apr 26, 2007
