Re: Trouble with the deck
Posted by Woodie on Apr 25, 2007
I have used the thinner door skins and not had any trouble. Another problem you may be having is the starps need to be on top of the deck beam. Then you start nailing from the deck beam forward. If you try to strap down the deck without the under support of the deck beam you will increase the probability of doing other damage like you have done.
In Response to: Re: Trouble with the deck by Walt on Apr 25, 2007
