Re: Planing sheer clamp o
Posted by Doug Arndt on Apr 17, 2007
Hi Chris, My brother and I are building a pair of these, however, his work schedule only allows us a day every week+, so you'll likely get your deck on first. Thanks for the note to and from John, that helps explain the "no curve" for that section. However, when I lay a piece on flat from the shear clamp to the carlin, the "inside" edge of the shear clamp is a bit high. So I was wondering if that edge (inside) should be planed instead of the normal outside edge as is the bow and stern. It would seem that it should be.
In Response to: Re: Planing sheer clamp o by Chris J. on Apr 16, 2007
