Re: Replacing the Skeg Pi
Posted by LeeG on Apr 16, 2007
Is it the wood dowel one? I was worried about that when the skeg kit used a wooden dowel as the pivot. It wouldn't take long for the skeg to wear through the epoxy coating in an environment of gritty mud/sand. Can a small right angle drill attachment work? At the hardware store there's a right angle attachment that's has two hex socket ends that can translate low power/speed work. Not the bigger one that has a regular chuck but a smaller one about 3/4" wide at the joint.
In Response to: Replacing the Skeg Pin by Tom Irvine on Apr 13, 2007
- here it tis by LeeG on Apr 16, 2007
Re: here it tis by Tom Irvine on Apr 16, 2007
- Re: here it tis by LeeG on Apr 16, 2007
- Re: here it tis by Tom Irvine on Apr 17, 2007
