Compartment leaks
Posted by Greg M on Apr 15, 2007
I�ve built three lap-stitch boats and in all of them I get water in the flotation compartments. The leaks occur when I have water in the boat, from waves or rain. I�ve resealed the drain plugs and checked all external fillets on the bulkhead and deck. I�m convinced that the joint leaks because I didn�t fillet the inside, where the bulkhead meets the uneven hull. I was lazy and felt that the outside fillet was strong enough.
I would guess that water inside the compartment will eventually rot the plywood, even with the epoxy seal. The drain never removes all the water. Should I cut a hole in the bulkhead, fillet the joint and install a deck plate? I don�t like the way they look on a wooden boat.
- Re: Compartment leaks by LeeG on Apr 16, 2007
- Re: Compartment leaks by CLC on Apr 16, 2007
Re: Compartment leaks by Ed, NY on Apr 28, 2007
- Re: Compartment leaks by Greg M on Apr 29, 2007
Re: Compartment leaks by Shawn on Apr 30, 2007
- Re: Compartment leaks by Greg M on May 1, 2007
- Re: Compartment leaks by John Beck on May 2, 2007
