Re: Scarf Joint on Deck
Posted by OOPS on Apr 13, 2007
Two better options: a) check if you have enough extra deck to cut the bow piece off and rescarf together (you'll lose about 1.5 inches if you are careful), b) call CLC or someone local to you and find out what it would take to get another small piece of 4-mm Okoume, then rescarf with a new bow piece. Lots of other ways to skin this cat, but these allow you to get a good scarf line on your foredeck. Good luck.
In Response to: Scarf Joint on Deck by Jim C. on Apr 13, 2007
