Re: HVLP gun
Posted by Jon B. on Apr 6, 2007
What a beautiful finish. That is what I'd like to do. How long have you been doing this? Maybe I'll hire you to put the last coat on my boats. I use Z-Spar/Captain's varnish. The can indicates no thinning required. If needed, use Petit T-10 thinner. How is penetrol different? I understand you add thinner for each coat? I've not tried the wet sand approach. What does it do vs. dry sanding; blends the scratches better? I use West System foam rollers. However I noticed when I ran a clean roller over the last coat of varnish, it left small particles so I'm convinced that is part of my "googie" problem.
In Response to: Re: HVLP gun by J. Schott on Apr 5, 2007
