by the way- on the wires
Posted by Charlie Jones on Apr 2, 2007
a very simple way to get them all the same length and make them very easy to cut.
Wrap the wire around a piece of 1 inch PVC or 1 inch dowel. Wrap about 5 or 6 inches, tightly. cut off the end from the roll.
Slide the wound on wire off the pipe or dowel and use tinsnips to cut right down one side. Since Pi works even with wire * grin*, using a 1 inch piece will give you roughly 3 inch wires.
In Response to: Re: Am I missing a page? by Ron Paro on Apr 1, 2007
- Re: by the way- on the wi by Greg Swarthout on Apr 2, 2007
