Re: deck glass isn't need
Posted by Laszlo on Apr 1, 2007
True enough, but the coaming is attached under ideal conditions (easy access, good visibility, not much area to glue so working time is not an issue). So it may just be a more dependable joint then the deck seam (which has poor access, no visibility while being assembled and is usually being assembled under mental pressure by the first time builders).
For experienced builders and chessies you're probably quite right.
In Response to: deck glass isn't needed by LeeG on Apr 1, 2007
- Re: deck glass isn't need by CLC on Apr 1, 2007
