Re: Varnishing
Posted by J. Schott on Mar 13, 2007
Thats the way I have been doing it. I can put a coat of varnish on a 17 in about 20 minutes using the roll and tip technique. Another plus is that you get a very uniform coat and you will have to try real hard to make runs or sags. Add a little penetrol to your varnish and you will be amazed at how well it will level out. You will have people swearing you sprayed it.-Joey
In Response to: Re: Varnishing by Jon B. on Mar 13, 2007
