Re: Fiberglassing Woops
Posted by LeeG on Mar 13, 2007
yep, re-glass in the dry wood areas. Are you using a disc sander or ROS sander? 60grit is too coarse, 80 grit with ROS is fine if you don't force it. It's not a matter of making it smooth, it's a matter of whether you know if you are sanding it evenly or not.
In Response to: Re: Fiberglassing Woops by Mike on Mar 12, 2007
