Re: Rubstrip/ Epoxy Quest
Posted by John Beck on Mar 5, 2007
Chris, If the boat is fiberglass then the same procedure applies. Just make sure you clean the area with appropriate solvent to remove wax followed by denatured alcohol wipe BEFORE sanding the area to be repaired.
John
In Response to: Rubstrip/ Epoxy Questions by Chris F on Mar 5, 2007
- Re: Rubstrip/ Epoxy Quest by Chris F on Mar 5, 2007
- Keel by Dave houser on Mar 5, 2007
- Re: Rubstrip/ Epoxy Quest by John Beck on Mar 6, 2007
- Re: Rubstrip/ Epoxy Quest by Chris F on Mar 6, 2007
