Re: maybe a Wave Ski?
Posted by Walt on Feb 1, 2007
Nathan If you are looking for a down-n-dirty Surf kayak try They sell a plan on DVD that is a bit on the crude side but you can build the boat for a small amount of $ in 2 weekends. I Modified there plan and built one last year to use for winter trips to the pool. Google surf kayak plans there are several boats that I found 2-3 SNG and a few others that shaped blocks of Styrofoam and then covered the shaped foam with a few layers of fiberglass. One of the glass hulls was called the gecko; on that webpage they walk you through the method used to develop the hull. Good luck Walt
In Response to: maybe a Wave Ski? by hwy12 on Feb 1, 2007
