Re: Sheer Clamp not Proud
Posted by Fred on Jan 29, 2007
Joe,I had the same problem with my sheer clamp.After sitting and thinking about the problem.The e-poxy and silica allows the two parts to move under clamping.At least its not a dry bonding join.Try you wife's hair dryer or a heat gun and gently and slowly heat the e-poxy,it should start to get soft and move.Good luck:Fred
In Response to: Sheer Clamp not Proud by JoeG on Jan 28, 2007
