Re: Epoxy
Posted by Laszlo on Jan 28, 2007
You are correct. What you're going for with the epoxy is general smoothness, not perfection. You just need the weave filled, the sags and runs removed and the air bubbles opened up and filled. The gloss will come from the varnish.
When have I filled the fiberglass weave with epoxy?
In Response to: Re: Epoxy by Kim on Jan 28, 2007
